Has anyone else experienced the issue where the car's data is turned off by default these past two days, and you have to manually turn on the network? How did you solve it?
How to turn off the two lights below the headlights?
The car is difficult to start two hours after turning off the engine.
Has any xV owner experienced the issue of not being able to remove the key after the engine is turned off? How did you solve it?
4What could be causing the central lock switch on the 2018 Dongfeng Renault Koleos 2.0 to work intermittently? Has anyone else experienced this issue, and how did you solve it?
5Is there a delay when starting the Renault Koleos 2019 model in cold weather? Has anyone else experienced this, and how did you solve it?
6The transmission light on your car suddenly turned on for a few minutes and then went off. Sometimes it lights up while driving, but it hasn't come on in the past few days. What could be the reason?
7Is there anyone who has experienced noise from the passenger side when turning on the air conditioning in the 2019 GAC GA6? How did you solve it?
8Has anyone else experienced the issue where the car's data is turned off by default these past two days, and you have to manually turn on the network? How did you solve it?
92016 model Touran L's air conditioning starts cooling, but stops after a while. Replaced the solenoid valve and cleaned the control board, it worked for two days and then the issue reoccurred. Has anyone experienced this? How did you solve it?
10Hey guys, does your infotainment system show no network and data being stolen by aliens? How did you solve it? Thanks, everyone.
