فهد شمس
2024-03-28 17:37
Guys, need some help. My Hongqi EHS9 460 Flag Enjoy suddenly has a dead battery today, but it was running fine yesterday. Jump-started it and went to the dealership for a full day check, but they couldn't find the problem. Has anyone experienced something similar? Any advice?
Comments( 7 )
حسن شعبان
حسن شعبان2024-04-19 02:28
Replace the small battery and update the software. The 460 is a battery. My first 460 had this issue, and replacing the battery and updating the software resolved it.
سلمان رجب
سلمان رجب2024-04-04 18:51
It's likely an issue with the small battery, report it to the manufacturer together.
نايف هكيل
نايف هكيل2024-04-03 23:44
Now I understand why electric cars depreciate so much. It turns out there are so many issues. Plus, a lot of benefits are only valid for the first owner, making them pretty useless for second-hand buyers.
علي خضير
علي خضير2024-04-03 10:06
The fact that the main battery has power but the auxiliary battery is dead suggests that the manufacturer's technology might not be fully mature. Generally, the main battery can charge the auxiliary battery. The solution is simple: just buy a jump starter, a low-power one will do. Spending around 200 can ease your worries.
علي منصور
علي منصور2024-04-01 19:08
I have it too, several times, can't solve it.
خالد حبيب
خالد حبيب2024-03-30 09:13
You should sell it quickly. If it were a gasoline car, it might still be considered a collectible, but since it's an electric car, it lacks solid strength and has issues everywhere.
عبد العزيز مراد
عبد العزيز مراد2024-03-29 09:58
Some fellow car owners have encountered this issue, but they didn't specify how they dealt with it at the time. It's normal for our 4S shop to not find the problem. Just ask them to send the data to the manufacturer and wait for a response.
Has anyone experienced a dead battery causing the anti-theft system to lock, and jump-starting didn't help?
My Peugeot 207's suspension feels quite stiff. Is there something wrong? Has anyone else experienced a similar issue with their car? I have a 2013 Peugeot 207 sedan.
Hello everyone, I have a question about my 2013 Skoda Rapid. It's been driven over 70,000 kilometers. Currently, when I press the accelerator above 60 km/h, I feel like the front wheels are shaking with the throttle. Has anyone experienced this? What's the issue here? I went for maintenance, but they couldn't identify the problem. They mentioned it might be the driveshaft. Has anyone had a similar issue? How did you resolve it?
Is the engine of the 2018 automatic model noisy while driving? Has anyone experienced something similar?
My car is 3 years old and sometimes it shows a right front indicator fault, but then the warning disappears. I've had it checked at the shop, but they couldn't find the cause. Has anyone else experienced a similar issue?
Noise issue, seeking advice from experts. I have a 2020 1.6 manual ASX. When driving on highways or national roads, once I go over 100 km/h, there's a knocking sound from the back after a bump, like a board isn't fixed properly. Yesterday, it was really annoying while on the national road. Even after stopping the car and restarting it, the knocking sound was still there. When I got home and tested it again, it was gone. This has been happening for a while, and I've checked multiple times but couldn't find the cause. Considering yesterday's situation, I suspect it might be an exhaust pipe issue. Has any fellow car owner experienced a similar problem?
Has anyone replaced their car battery? I drive often, and last night the battery was dead and I couldn't start the car. Have you guys encountered this before?
I went for a test drive of the 009 yesterday, and the smell was quite strong. I felt nauseous for the whole afternoon afterward. Have any of you experienced something like this?
Hello everyone, I have a question: My Mazda 6 had the engine light and oil light come on after shifting to neutral while waiting at a traffic light. The idle was normal, but there was no response when I pressed the gas pedal and shifted to drive. After restarting the car, everything went back to normal. I went to the dealership, but they couldn't find any error codes. Has anyone experienced something similar? How can I fix it?
