Do I have to go to the 4S store to replace the small battery in the car? Any advice from fellow car owners (EHS9)!
My Previa's remote key won't unlock the doors, even after changing the battery. What's going on? Fellow car owners, can you please advise on how to fix this? Thanks a lot!
I'm wondering how to modify the GA6. Any suggestions from fellow car owners?
4Do I need to replace both small batteries if one of them is dead? Please help, everyone.
51.4T engine, when replacing the ignition coil, which OEM brand is good? Any recommendations from fellow car owners who have changed theirs?
6Should I replace the battery at the 4S shop or do it myself? I'm torn.
7Acura Zhi Xiang version has been running for 4 years and 80,000 kilometers. It started having difficulty starting yesterday, but the battery didn't show any warning. Does this model not alert for battery degradation? Do I need to replace the battery with these symptoms? Looking for advice from fellow car owners who have changed their batteries, 🙏
8Where do you all go for maintenance? The 4S stores are getting more and more expensive now.
9Should I choose the 2024 Zeekr 009 with a 400V long-range 140kWh battery or the 800V high-voltage 108kWh battery? Any advice from fellow enthusiasts?
10Is there any owner who has experienced a clunking noise from the chassis when making a U-turn with the steering fully turned? I went to the 4S store, and they said it's a problem with the half axle and needs replacement. Has anyone else encountered this?
