علي آدم
2024-04-04 21:39
Where should I insert the USB drive in the Hongqi HS7 to play music? I've tried both the slot under the dashboard and the one at the back, but it shows "USB not mounted". What should I do?
عمر حازم
عمر حازم2024-06-08 16:25
If it can't be recognized, try using a USB drive with smaller memory.
عمر حازم
عمر حازم2024-06-08 16:23
Open the small cover on the right side of the wireless charger. Only this USB port can play music from a USB drive, while the other ports are for charging only.
