جلال الدين فهد
2024-01-24 19:23
Where is the jack located in the 2023 Hongqi HS7?
خالد فريدة2024-08-17 23:29
Why do you need a jack if there's no spare tire?
خالد نادر2024-01-28 05:57
There isn't one, because there's no spare tire, so there's no jack either.
فهد حارث2024-01-25 23:49
Under the trunk
عبد العزيز فرج2024-01-24 21:14
I'll let you know once I've bought it.
When will the 2023 version of the Hongqi H7 be released?
Does the Hongqi HS7 not come with a spare tire?
4What is the function of the five exterior cameras on the new Hongqi HS7? 🙏🙏🙏
5Is the Hongqi HS7 worth buying?
6How many batteries does the Hongqi HS7 have?
7Is the fuel consumption high for the 2023 Hongqi HS7 4WD?
8What chip does the Hongqi HS7 use for its infotainment system? Is it smooth?
9What chip does the Hongqi HS7 infotainment system use?
10Is the Hongqi HS7 only available in an electric version, without a fuel option?
