عَبْدُ الْعَزِيز نايف
2024-05-29 10:24
What is the function of the five exterior cameras on the new Hongqi HS7? 🙏🙏🙏
عمر حازم2024-06-08 16:15
Front, rear, left, and right monitoring, 360-degree view.
عبد العزيز عمرو2024-05-29 15:29
Showing you every angle, afraid you might not make the turn [I need some peace].
Where is the jack located in the 2023 Hongqi HS7?
Does the Hongqi HS7 not come with a spare tire?
4Is the Hongqi HS7 worth buying?
5How many batteries does the Hongqi HS7 have?
6Is the fuel consumption high for the 2023 Hongqi HS7 4WD?
7What chip does the Hongqi HS7 use for its infotainment system? Is it smooth?
8What chip does the Hongqi HS7 infotainment system use?
9Is the Hongqi HS7 only available in an electric version, without a fuel option?
10Has anyone with a HS7 encountered a camera malfunction where it shows a "cannot connect to camera" message?
