محمد نور الدين
محمد نور الدين
Oct 19
Has anyone noticed that the steering wheel and the seat aren't aligned? The steering wheel is a bit off to the left. 🤯🤯🤯🤯🤯🤯 Currently trying to get used to it 🤐🤐🤐🤐🤐🤐
Comments( 8 )
خالد مسعود
خالد مسعود2024-11-18 20:31
Ah? No, there isn't.
أحمد نور الدين
أحمد نور الدين2024-11-18 10:10
I didn't notice it either, I'll take a good look when I go back.
عبدالله معتصم
عبدالله معتصم2024-11-03 21:07
I feel the same way.
خالد فريدة
خالد فريدة2024-10-26 19:05
I haven't really paid attention to that.
عبد العزيز عمرو
عبد العزيز عمرو2024-10-25 11:51
My car pulls to the right when parked.
ابيض عبد العزيز
ابيض عبد العزيز2024-10-25 10:04
I really didn't notice, it's quite decent.
فهد مطلب
فهد مطلب2024-10-24 14:05
It's okay, I'm leaning to the right [I want to be alone].
عبد العزيز عمرو
عبد العزيز عمرو2024-10-20 09:34
"I'm looking for some peace and quiet."
The steering wheel of the 2016 Crossover Yizhi is not aligned properly and is tilted to the left. The left side is further from the driver, and the right side is closer. Has anyone else experienced this issue, and is there a solution?
Hey guys, my Land Cruiser tends to pull the steering wheel when driving on bumpy roads, and it doesn't feel very stable. I've already done a wheel alignment, and the mechanic said there's nothing wrong. Is the steering wheel pulling a normal phenomenon?
How can I adjust the steering wheel weight on the Tucson L? The steering wheel feels too light and a bit wobbly when driving at high speeds.
Do you have the issue where the steering wheel is straight, but the car veers to the left?
When turning the steering wheel of the MG HS, there's a clicking sound on the left side.
Do you also have to slightly turn the steering wheel to the left when driving straight on the road?
On the day of the Mid-Autumn Festival, the reverse camera and 360 stopped working. I went to the 4S shop the next day for recalibration to fix it. Because the steering wheel was vibrating while driving on the highway, I did a wheel balancing and four-wheel alignment. Today, while driving on the highway, I noticed that the speed range at which the steering wheel vibrates has expanded, and now the seat also vibrates above 124 km/h. Can any expert provide some guidance?
Has anyone done a wheel alignment? My City has uneven wear on the left rear tire and slightly pulls to one side. I've heard that the City’s rear wheels are non-adjustable and you can only add shims during alignment. Is this safe? Also, is it necessary to do a wheel alignment since the tires are quite cheap? 🤦‍♂️
The steering wheel is crooked 🤦‍♂️. Even after doing a wheel alignment, it can't be fixed. The mechanic said it's caused by a deformed lower control arm?
I recently bought the 2024 Tiida Intelligent Edition and it's my third time driving on the highway. When I reached 130 km/h, I noticed that after exiting the highway, the steering wheel needs to be slightly turned to the right to go straight. If I keep it centered, the car veers to the left. Is this normal? Also, is getting a wheel alignment expensive?
Hongqi HS7
Hongqi HS7KWD 14,272 ~ 21,999Gasoline & Petrol
