حسين يعقوبي
2022-01-14 08:39
When using the paddle shift manual mode in the HS with the S gear, do I need to press the brake pedal to change gears? In the past, when I drove a fully manual transmission, there was a clutch pedal. [Facepalm][Facepalm][Facepalm][Facepalm]
Comments( 7 )
محمد مستنصر
محمد مستنصر2023-10-05 21:09
No need to use the brake, generally don't use the S gear, mostly use the D gear. S gear might consume too much fuel.
عبدالرحمن تكريتي
عبدالرحمن تكريتي2023-07-11 17:53
No need to press the pedals at all.
عبدالرحمن تكريتي
عبدالرحمن تكريتي2023-05-26 09:26
No need to press the brake pedal.
عبد العزيز إبراهيم
عبد العزيز إبراهيم2022-01-14 12:54
You don't need to step on the brake, but I feel that just pressing the accelerator and using the paddle shifters to shift gears is somewhat slower, and the RPM tends to be higher. Adjusting the throttle pressure slightly can improve it a bit. If you like, you can gradually get used to it.
علي شهيد
علي شهيد2022-01-14 11:47
It's not necessary, but if you keep pressing the accelerator while manually shifting gears, there can be some jerking. Sometimes, you need to ease off the accelerator to shift gears smoothly.
أحمد ق
أحمد ق2022-01-14 10:37
Not needed.
علي منصور
علي منصور2022-01-14 09:03
The manual indicates that the "S" gear is the Sport mode. I'm still figuring out how to use the paddle shifters.
When the engine is idling, the RPM is stable at around 800. However, when you press the clutch and shift gears, the RPM increases to 1200 (without releasing the clutch, just purely shifting gears). What could be the reason for this? (The transmission, clutch, and flywheel have been checked and there are no abnormalities.) Car model: Manual rear-wheel drive Mazda 6-speed manual RX-8 Type S.
How do you switch between the advanced mode and normal mode of the Phaeton's air suspension? In the advanced mode, is the front lower and the rear higher when parked? [Facepalm]
Is your 2018 manual KIA Pegas with 70,000 km experiencing difficulty in shifting gears, often failing to engage and grinding? It seems like the clutch isn't fully disengaging. Could this be a clutch issue or a problem with the gear linkage? How can it be resolved?
The clutch on the 2.3T manual Ousheng makes a clunking sound when released halfway.
What could be the reason that the brake pedal cannot be pressed down when turning the steering wheel fully or reversing?
This morning I noticed that there are only 7 gears in manual mode, what's going on?
1. Does anyone know if it's normal for there to be a "thud" sound when quickly releasing the clutch from first to second gear in a manual Suzuki Swift? 2. When pressing the clutch to engage first gear, sometimes there's a "thud" sound near the left foot. What's the issue?
[Shocked] What's up with this car? Starting in S mode, I floored the pedal, the RPM hit 4000 and it was still in 2nd gear without shifting up automatically. It only shifted to 3rd gear after releasing the throttle for 3 seconds.
MG MG HS
MG HSAED 79,000 ~ 93,000Gasoline
