محمد مستنصر
محمد مستنصر
Oct 5
When I floor the accelerator on my 2.0T model, the RPM only goes up to 3000 and won't go any higher. Is this normal for everyone else's car too?
Comments( 7 )
سلمان خلف
سلمان خلف2023-11-27 16:26
Idling is definitely a form of protection!
فهد تاج
فهد تاج2023-11-09 18:00
My car is like yours, it can only go up to 3000 RPM, can't go any higher. [I want to be alone]
محمد مستنصر
محمد مستنصر2023-10-22 22:15
Dear fellow car enthusiasts, I drive an MG HS 30T. I've seen many comments from others with the same car, mentioning an average fuel consumption of 8 or 9 liters per 100 km. Why can't mine go below 11.5? I'm often driving in the city.
سلمان طائي
سلمان طائي2023-10-13 20:50
My 1.5T sometimes has the RPM go up to 2000 and then come back down when at low speed.
خالد حارث
خالد حارث2023-10-13 08:12
There is RPM protection when revving the engine without load.
أحمد ق
أحمد ق2023-10-06 08:30
Sport mode, 4500 RPM.
حسين عبيد
حسين عبيد2023-10-05 23:54
Idle speed, right! Program design protection.
Registered in November 2015, 1.5T Luxury version, driven 100,000 km. Recently, when accelerating a bit too hard, it feels like it shifts to neutral; the engine revs, but the dashboard still shows D gear. If I release the gas pedal and wait for a second or two, then accelerate slowly, it goes back to normal. I can't accelerate suddenly, only gradually. Has anyone else experienced this problem? It's been repaired several times but still not resolved.
Is it normal for the Sharan to shift gears at 3000 RPM when climbing?
Is the exhaust sound on the 2016 3.0 standard only activated at 3000 RPM? Can it be modified?
Hey everyone, is it normal for the car's RPM to stay around 1200 even when I release the accelerator while driving? The idle speed is only 800 RPM when parked in neutral. Is it the same for you guys?
2017 model 1.4T, now the temperature is around 3°C. When I start the car, the RPM is at 1200, and when I start driving with a cold engine, the RPM goes above 3000 before it shifts gears, and it feels shaky. Do you guys experience this too?
At 120 km/h, how many RPMs does your Honda City engine run at? Mine goes over 3000 RPM. Is that normal, and how can I fix it?
Hello everyone, when I start my car cold, it makes a "dada" sound and the RPM goes up to over 1000, but it goes back to normal after about a minute. Is this normal?
I'm seeking advice from experienced Scirocco owners. I have a 2012 2.0T Scirocco, and every time I accelerate a bit harder and the RPM goes higher, the EPC warning light comes on. I went to a mechanic before, and they just cleared the code, saying it was nothing serious. But recently, it’s happening more frequently. Can any experienced drivers explain what's going on? Thanks!
MG HS
MG HSOMR 7,345 ~ 10,375Gasoline & Petrol
