حسن يعقوبي
حسن يعقوبي
Apr 28
Is it normal for the left side of the hood on the 2019 HS 2.0 Super Edition to be hot after parking? After about half an hour, it cools down and the whole hood is warm, but the temperature is acceptable.
أحمد صعب
أحمد صعب2024-04-29 16:59
Ah... It's normal for the engine heat to cause the hood to get hot. [I want to be quiet][I want to be quiet] Or? Is the water temperature gauge normal? If there's no warning from the water temperature gauge, then it's normal, no problem.
When the car starts, the ESP warning and engine fault warning appear, and it can't shift gears. It needs to warm up for half an hour before it can move. How can I solve this?
My Scirocco feels jerky when shifting in S mode. At half throttle, it reaches 4000 RPM and reports an engine fault that needs repair. The EPC light is on, and it mentions something about oil pressure and the engine's maximum speed at 4000 RPM. What's going on, experts? Once I restart the car, everything seems fine (after the car is warmed up, with both water and oil temperatures up to normal levels).
Cayenne steering wheel noise: When the car is cold, there's no issue; it's very smooth. After driving for a while (around 1 hour), especially in hot weather, there's a squeaking noise when turning the wheel. Do any fellow car enthusiasts have the same issue? I saw on a social media platform that it might be the airbag clock spring?
When starting a 2005 Prado 2.7 from a cold start or after it's been sitting for about half an hour, there's a strange noise. I've already replaced the starter motor, but the issue persists. Does anyone have any ideas on what might be causing this?
When I turn on the air conditioning, the cooling fan starts spinning, then stops after a while. The cycle of spinning and stopping is roughly one minute. Even after turning off the car, the fan keeps running and won't stop. Only by restarting the car and then turning it off again does the fan stop. Could the temperature sensor be malfunctioning? Any insights from the experts?
I got a 2021 Murano in July 2021, and just recently on a long drive, I found that the AC was blowing hot air with no cooling. After visiting the repair shop and refilling the refrigerant, the AC started cooling again. The car is just 3 years old, is it normal for the refrigerant to run out so quickly, or could there be a leak?
How to exit the economy mode on a 2013 Peugeot 508? 😅😅 After my dad used it, I played with the key for half an hour and it entered some kind of economy state.
Fellow car enthusiasts, have any of you experienced this situation where the transmission control system malfunctions, the power can't be turned off, the key fob lock button stops working, and then everything returns to normal after about half an hour to an hour? It's a three-month-old car, and this issue has occurred multiple times. I've been to after-sales service, but it hasn't been resolved.
MG HS
MG HSKWD 6,250 ~ 8,265Gasoline & Petrol
