نايف صدام
2023-09-26 16:29
Is anyone familiar with solving the issue of idle speed occasionally rising to 2000 RPM and then dropping back down on a stock MG HS? It's particularly noticeable at low speeds.
عبدالله وهاب
عبدالله وهاب2023-09-26 22:56
I feel the same way. The jerking is noticeable and there's no fix. As long as it's cheap, it's fine.
فهد عائشة
فهد عائشة2023-09-26 17:08
You can just go to the 4S shop and connect the car to a diagnostic computer to check for any issues. It could be oil, electric, or gas leaks, or a sensor problem. The computer won't lie.
I have a 2017 MG GS and the airbag warning light sometimes turns on. It lights up occasionally, especially when going over speed bumps. Has anyone else experienced this issue?
It's normal for your NV200 to have a high idle speed of 2000 RPM when you start it cold, and then drop to 800 RPM after about a minute. This process helps the engine warm up. However, if it feels inconvenient, you might want to consult a mechanic to see if any adjustments can be made.
If you're deciding between the MG ZS and MG HS in Europe, here are some considerations: MG ZS comes with a 1.0T engine and a 6-speed automatic transmission. However, it's a three-cylinder engine. On the other hand, the MG HS features a 1.5T engine with a dry dual-clutch transmission and is a four-cylinder. There are reports online that the MG HS might experience significant jerking issues after a year or two due to the dry dual-clutch transmission. You might want to weigh the pros and cons of each engine and transmission type based on your driving preferences and needs.
How to solve the issue of no idle speed increase when starting a cold 2019 Renault Koleos?
Is it normal for the idle speed of a 2015 Volkswagen Touran to rise to 900 RPM when the outside temperature is below 0 degrees while the engine is warm?
HS 30T 2WD, when driving on the highway, the steering feels sticky and doesn't return to the center, making it tiring to constantly adjust. This doesn't happen at low speeds or in hot weather. Has anyone else experienced this? How did you solve it? Some say it's an issue with the steering gear and needs a full replacement—is this true?
When starting a cold car, the RPM goes up to 2000 and then drops to 1500 but doesn't go any lower. The high idle speed is causing high fuel consumption, 20 liters for 300 kilometers! The idle speed is too high, and so is the fuel consumption. Can any experts provide a solution? 🙏
When I start the car, the idle speed is around 2000 RPM, but after a while, it drops to 1500 RPM. It takes quite a long time to go down to around 1000 RPM. Does anyone know what's going on?
I need some advice from experts: I have a 2013 1.4T Touran. Recently, the engine occasionally makes a loud noise after starting, and the idle speed is over 1100. But after turning off and restarting, the engine sounds normal, and the idle speed is around 700, back to normal. What could be the issue?
MG MG HS
MG HSAED 79,000 ~ 93,000Gasoline
