If you're deciding between the MG ZS and MG HS in Europe, here are some considerations: MG ZS comes with a 1.0T engine and a 6-speed automatic transmission. However, it's a three-cylinder engine. On the other hand, the MG HS features a 1.5T engine with a dry dual-clutch transmission and is a four-cylinder. There are reports online that the MG HS might experience significant jerking issues after a year or two due to the dry dual-clutch transmission. You might want to weigh the pros and cons of each engine and transmission type based on your driving preferences and needs.
Comments( 12 )
Is the dry dual-clutch of T-Cross prone to high failure rates? How is the overall quality?
How do you distinguish between the 451 and 453 models, AMT and dual-clutch transmission?
4Is there any problem with the transmission vent valve oil leak on a 2018 MG ZS automatic? Asking the experts.
5When buying a car air pump, why differentiate between single-cylinder and double-cylinder? Is the MG ZS single-cylinder or double-cylinder?
6Is it normal for the MG ZS to have sluggish acceleration and a rattling noise from the engine?
7Does upgrading the system at a 4S dealership help with the jerking issues of the MG ZS 2020 model's transmission?
8MG ZS intermittent engine fault code. It disappears and then reappears, how to deal with it?
9How to handle the occasional engine warning light in the 2020 MG ZS?
10Are cars still using dual-clutch transmissions (DCT) at over 50? Why not switch to an automatic transmission (AT)?
