I need some help. I have a 2019 MG HS 1.5T, and it's run for 37,000 kilometers. The engine pulley makes a squeaking noise when I release the accelerator, and it also makes noise when I turn on the AC. What should I do? I just replaced the alternator pulley, but it didn't help.
There is a strange noise when I turn on the air conditioning, and adding refrigerant didn't help. The temperature is still okay, but I'm not sure what the issue is.
My MG GT experiences jerky acceleration, and there's a squeaking sound when I turn the steering while driving. Additionally, there's a squeaking noise when I rev the engine after parking. What could be the issue?
When I press the clutch, there's a squeaking noise, but it goes away when I release it. Is there a problem?
4When I turn on the AC, it makes a noise... After a while, it gets a bit better, but when I stop the car, it starts making noise again... Has anyone experienced this? Thanks.
5If you're deciding between the MG ZS and MG HS in Europe, here are some considerations: MG ZS comes with a 1.0T engine and a 6-speed automatic transmission. However, it's a three-cylinder engine. On the other hand, the MG HS features a 1.5T engine with a dry dual-clutch transmission and is a four-cylinder. There are reports online that the MG HS might experience significant jerking issues after a year or two due to the dry dual-clutch transmission. You might want to weigh the pros and cons of each engine and transmission type based on your driving preferences and needs.
6The transmission is making a loud noise, like a whistle. I even changed the transmission oil, but it didn't help. Has anyone else experienced this?
7The engine of the 2014 GS5 is making a squeaking noise. What could be the problem?
8I need some help. I have a 2019 MG HS 1.5T, and it's run for 37,000 kilometers. The engine pulley makes a squeaking noise when I release the accelerator, and it also makes noise when I turn on the AC. What should I do? I just replaced the alternator pulley, but it didn't help.
9When turning the steering wheel of the MG HS, there's a clicking sound on the left side.
10Has anyone experienced this? The X90plus's wipers make a squeaking noise after only six months?
