محمد محملة
محمد محملة
Feb 21
HS 30T 2WD, when driving on the highway, the steering feels sticky and doesn't return to the center, making it tiring to constantly adjust. This doesn't happen at low speeds or in hot weather. Has anyone else experienced this? How did you solve it? Some say it's an issue with the steering gear and needs a full replacement—is this true?
خالد عبد القادر
خالد عبد القادر2024-03-22 17:45
Same here, went to after-sales for a test drive and they said there's no problem.
What causes the steering wheel not to return to center automatically?
When the air conditioning blows cold air for a while and then switches to hot air, and after being turned off for a bit, it works again before reverting to hot air, it's puzzling. Interestingly, this issue doesn't occur on rainy days or when the weather isn't too hot. What could be the cause of this situation?
Hey fellow car enthusiasts, with the 2023 GV80, has anyone experienced the steering wheel not returning to center on its own, needing manual turning back?
Does anyone feel that the steering of the Tucson tends to drift on the highway? I constantly need to make small adjustments. Is there no self-centering, or is there a setting for this? It's quite tiring to drive like this.
Hi everyone, I have a 2017 Murano and noticed that the steering wheel doesn't return to the center after turning. Is this normal for you guys? I just discovered this issue.
Does your Alto automatically return to the center when you turn the steering wheel?
Hi everyone, just wondering if the steering wheel of the Skoda Rapid doesn't return automatically when driving at low speeds?
Why is the steering on my 2018 X-Trail heavy and not returning to center automatically?
Steering feels stuck and doesn't return to center. How do you guys deal with this? I've heard it can be fixed by reapplying grease to the steering gear. How much does it roughly cost?
MG HS
MG HSKWD 6,250 ~ 8,265Gasoline & Petrol
