لاويل عبدالرحمن
لاويل عبدالرحمن
Jun 23
How to activate the MG HS Super version Bluetooth module?
فهد عائشة
فهد عائشة2024-06-23 08:06
Disconnect the battery to cut off the power → Reconnect the power → Use a car diagnostic tool for a full vehicle check → Clear fault codes accordingly → Reconnect Bluetooth After using my car for a while, I found that I could only control the climate remotely and couldn't use my phone as a key to start or stop the vehicle. Some people online mentioned that restarting the Bluetooth after disconnecting the power might help. After following the steps above, my phone could once again be used as a car key through the Zebra App or MG App.
How to connect Bluetooth to play Bluetooth music?
If you're deciding between the MG ZS and MG HS in Europe, here are some considerations: MG ZS comes with a 1.0T engine and a 6-speed automatic transmission. However, it's a three-cylinder engine. On the other hand, the MG HS features a 1.5T engine with a dry dual-clutch transmission and is a four-cylinder. There are reports online that the MG HS might experience significant jerking issues after a year or two due to the dry dual-clutch transmission. You might want to weigh the pros and cons of each engine and transmission type based on your driving preferences and needs.
Is anyone familiar with solving the issue of idle speed occasionally rising to 2000 RPM and then dropping back down on a stock MG HS? It's particularly noticeable at low speeds.
Does anyone still have the MG HS maintenance manual? Can you share it?
Looking for help, how do I turn on the fog lights on the MG ZS? And where do I activate the external circulation?
Is it normal for the left side of the hood on the 2019 HS 2.0 Super Edition to be hot after parking? After about half an hour, it cools down and the whole hood is warm, but the temperature is acceptable.
How do I reset the system after upgrading the MG HS Zebra system to the Venus system and after maintenance?
Where can I activate the active braking on the Cetus 1.5L naturally aspirated, luxury version?
When turning the steering wheel of the MG HS, there's a clicking sound on the left side.
MG HS
MG HSQAR 72,000 ~ 98,168Gasoline & Petrol
