نايف مهدي
2022-12-31 11:19
Hey folks, I need some advice. I just changed my car battery, and the starting power seems strong. But why does it show low battery voltage as soon as I turn off the engine? Even after driving 100 kilometers, it still reports this issue. What's the reason?
عبدالرحمن حموي
عبدالرحمن حموي2023-12-12 00:49
Hey, it's the end of 2023, and still many car enthusiasts don't know that the battery drain bug could be fixed with an update since the end of 2019.
حسين عَبْدُ الْعَزِيز
حسين عَبْدُ الْعَزِيز2023-12-08 15:53
It's getting cold, and the car battery isn't lasting long.
لبيب نايف
لبيب نايف2023-11-28 20:11
Was it resolved later?
فهد عائشة
فهد عائشة2023-01-02 21:12
Does this car have an auto start-stop feature? It seems like there's an auto start-stop module near the battery. The battery you replaced isn't an auto start-stop battery, is it?
I recently watched a video showing many new energy vehicles with strong water-wading capabilities. How does the C40 perform in this aspect?
Guys, I don't get it. Both the S and X have 100° batteries, so why does the X show 535 and the S shows 630?
What could be the reason that there seems to be something blocking the brake pedal when I press the brake on a 207?
The 80th Anniversary Edition car with a 1.3T engine showing a battery voltage of 12.1V when running seems a bit low, doesn't it?
Why do I feel a strong drag when I release the accelerator? Does anyone else experience this? I have a 2024 Forester 2.5 with less than 1000 kilometers. What could be the reason? Looking for advice.
Can I use the air conditioning while charging the AION on high-voltage charging? How can I do it without damaging the battery and the small battery? Thanks!
Should I choose the 2024 Zeekr 009 with a 400V long-range 140kWh battery or the 800V high-voltage 108kWh battery? Any advice from fellow enthusiasts?
The car often reports that it can't detect the key as soon as I open the door... The key is a replacement. What's going on?
When I start the car, the dashboard shows "Auto Start-Stop Unavailable" and then "Check Engine". What's going on? I just replaced the battery not long ago.
MG MG HS
MG HSAED 79,000 ~ 93,000Gasoline
