SAIC Maxus 2020 T60 2.0T diesel 4WD, 1.5 years old. There's a vibration noise coming from the center console when the RPM is between 1800 to 2000 in low gear. What could be the cause?
My MG GT experiences jerky acceleration, and there's a squeaking sound when I turn the steering while driving. Additionally, there's a squeaking noise when I rev the engine after parking. What could be the issue?
Lately, I've noticed that when I start driving, the car stays in first gear until 2500 RPM and then suddenly shifts with a big jolt.
4Is it normal for a 2015 model to have a smooth start without accelerating, but require around 2000 RPM to start with acceleration, and then feel a noticeable jolt and tire slip?
5Hello everyone, could someone help me with this issue? When in Park and idling, if I rev the engine above 1600 RPM and then release the throttle, the RPM stays around 1600 for about ten seconds before it drops. This doesn't happen if I don't exceed 1600 RPM. Between 1600 and 2000 RPM, there's a noticeable jolt. Additionally, when shifting gears and slowly accelerating, there's a rattling noise between 1600 and 2000 RPM, but it disappears after 2000 RPM. Does anyone have any insights on this? I would really appreciate it. The car model is a 2016 30T two-wheel drive. Thank you very much!
6When I start the car, the idle speed is around 2000 RPM, but after a while, it drops to 1500 RPM. It takes quite a long time to go down to around 1000 RPM. Does anyone know what's going on?
7Hi everyone, I have a 2013 Suzuki Alto automatic. When I start and just slightly press the accelerator, the RPM quickly goes up to 2000. Even when the speed reaches 60, the RPM stays around 2000. What's going on here?
8Has anyone experienced repeated jerking at a certain RPM (mine is at 1500-1600)? Lightly pressing the accelerator to maintain this RPM causes repeated jerking, but it stops if I accelerate more or release the pedal. This issue has randomly appeared several times and then mysteriously resolved itself.
9Hey car enthusiasts, can anyone help me out? My 2015 manual Sunny only revs up to 2000 RPM when I floor the gas pedal, and the acceleration feels weak. What could be the issue?
10Help needed, fellow Peugeot owners! Ever since my little Peugeot went on a continuous uphill drive for over an hour a few days ago, it's been having issues. The RPMs go up, but the speed doesn't. It's not too bad when not on the highway, as pressing the accelerator quickly gets the RPMs and speed up. But once I'm on the highway and going over 80-90 km/h, I need to press the gas to at least 2000 RPMs for the speed to increase very slowly. On inclines, if I don't reach 2500 RPMs, the speed drops. I never had to go over 2000 RPMs on the highway before. What's going on? 🌹
