عبدالله معتمد
عبدالله معتمد
Apr 24
Hello everyone! A while ago, I posted about the jerking and hesitation during low-speed starts. Recently, I found some information online suggesting that the 6-speed wet dual-clutch transmission, model DCT360, from SAIC had design flaws. Is this the transmission model used in the MG HS 2.0T? If it is, does the issue of the car not moving with light acceleration and jerking with heavy acceleration count as a common problem due to design flaws? If not, is there any way to resolve it?
Comments( 7 )
حسن يعقوبي
حسن يعقوبي2024-06-01 15:15
My car with a 2.0T engine has a strong jerk when I accelerate at the start, it feels like the car is lurching forward. If I give less gas, the start is slow, but even with a little more gas, the car still jerks! When reversing downhill, it feels like the car doesn't move even when I rev the engine. Can experienced drivers share how to deal with this? Once I'm driving normally, everything feels smooth.
فهد تاج
فهد تاج2024-05-08 21:41
I always thought it was the power that caused the push-back feeling.
شخبوط عبدالرحمن
شخبوط عبدالرحمن2024-04-25 18:16
All dual-clutch transmissions are the same.
شخبوط عبدالرحمن
شخبوط عبدالرحمن2024-04-25 18:15
My car also has this issue with slow starts, it's a common problem with dual-clutch transmissions.
أحمد ق
أحمد ق2024-04-25 08:31
SAIC's 6-speed wet dual-clutch has a simplified version with reduced torque and downgraded materials, sold to smaller domestic brands. The quality is quite a bit worse. You can try disabling the electronic parking brake and then test parking and starting again. If you accelerate too much with the electronic parking brake, the electronic unlocking and car start are linked, which can cause the car to jerk. First, gently press the accelerator to unlock the electronic parking brake, release the accelerator, and then gradually press the accelerator again.
فهد عائشة
فهد عائشة2024-04-25 06:28
The wet 6-speed transmission is for the 30T, and the dry 7-speed transmission is for the 20T. Online, it's mentioned that after installation in models like Zotye and Liebao, the wet 6-speed transmission has a plastic slider on the clutch that tends to crack. Once it cracks, the clutch slips, and the fragments block the transmission oil filter, causing abnormal oil shortages. If that's truly the case and the transmission fails, you can just take it apart and replace the parts. There's a car in the group that has run 240,000 km, and it's still doing fine.
عبدالله معتمد
عبدالله معتمد2024-04-24 16:53
Thanks in advance for sharing your insights [thumbs up][thumbs up][thumbs up]
Does anyone know why the 2.0 naturally aspirated engine with 6-speed wet dual-clutch can't shift gears in manual mode? How do you fix severe engine vibrations? But once you accelerate, there's no vibration. Also, there's an issue with lack of power when climbing hills. Last time, I almost got stuck in the basement because the engine revved up to 5000 RPM.
Does the manual transmission of the Navara still have the inherent design flaw of being easily damaged by water ingress?
Is the 2022 GA6 experiencing jerking when shifting from second to third gear and also when accelerating at low speeds in third gear a common issue for this model?
If you're deciding between the MG ZS and MG HS in Europe, here are some considerations: MG ZS comes with a 1.0T engine and a 6-speed automatic transmission. However, it's a three-cylinder engine. On the other hand, the MG HS features a 1.5T engine with a dry dual-clutch transmission and is a four-cylinder. There are reports online that the MG HS might experience significant jerking issues after a year or two due to the dry dual-clutch transmission. You might want to weigh the pros and cons of each engine and transmission type based on your driving preferences and needs.
What could be the reason for a vehicle with an 8-speed automatic transmission to jerk when shifting from 3rd to 2nd gear?
2010 Peugeot 307, automatic transmission. Why does it make a squeaking sound every time I accelerate at low speed and then suddenly release the accelerator?
When slowly accelerating at low speeds, the V60 B4 2024 model experiences noticeable jerking and dragging.
When lightly pressing the accelerator at low speeds, there's a slight jerk, and when the RPM drops below around 1100, there's a dragging feeling. What could be the problem?
What could be the issue with a 2016 Jeep Grand Cherokee 3.0 where the 8-speed transmission won't accelerate?
MG HS
MG HSEGP 411,990 ~ 1,570,000Gasoline & Hybrid & Petrol
