عباد فهد
2025-02-14 15:44
How much is Hyundai i10 service?
حارث سعود2025-02-21 19:14
Hi there! If you're wondering about the cost of servicing a Hyundai i10, you should know that several factors affect the price. An oil change and filters can cost you between 300 to 500 AED, but don't forget to add in other costs like a thorough inspection. Remember, regular maintenance is super important!
محمود محمد2025-02-19 19:33
Hey there! The cost of servicing a Hyundai i10 really depends on the type of service you need. For instance, if you're looking at an oil change and filters, it usually falls between 300 to 500 AED. However, if you're considering a comprehensive inspection or regular maintenance, you could be looking at around 1000 AED. Always a good idea to check with authorized centers for the best prices!
أكرم عبد العزيز2025-02-19 10:08
Peace! The cost of servicing a Hyundai i10 really depends on what service you need. An oil change and filters are usually between 300 and 500 AED, but it could go up to 1000 AED if you need a comprehensive inspection. Have you tried checking with authorized service centers?
هشام سلمان2025-02-17 14:51
Hey there! When it comes to how much is Hyundai i10 service, it really depends on the type of service your car needs. Generally, routine service costs between $80 to $200. This typically covers oil changes, brake checks, and tire inspections. If you have larger issues, like replacing parts, the cost can go up. For instance, replacing a Hyundai i10 battery might set you back around $130. It's always best to check with a reliable service shop for an accurate estimate. Drive safe!
إسماعيل حسين2025-02-17 14:51
Hey there! So, the cost of servicing the Hyundai i10 can vary based on your location and the type of service you need. Typically, for regular maintenance like oil changes and filter replacements, you might be looking at a cost between $50 to $150. If you're going for a more comprehensive service, it could go up to $300 or more. It's always a good idea to check with your local Hyundai dealer for an accurate estimate.
If you're comparing the Hyundai i10 with other models, I can definitely help you out with that too! For instance, the i10 is well-known for its fuel efficiency and compact size, which makes it great for city driving.
How to connect Bluetooth on a Hyundai Accent?
Isn't it just the Hyundai iX25?
How much is this?
4How often should the Multivan be serviced?
5How often should the Ghost be serviced in terms of kilometers?
6How long is the body of the Hyundai i10?
7How often should a new car be serviced in terms of mileage?
8Can I get this car serviced at a Hyundai 4S shop?
9My Subaru Forester has run 60,000 kilometers and needs a major service. How much will it cost?
10How many free maintenance services does the manufacturer provide?
