How much does an oil change for a Chevrolet Aveo cost at maintenance centers? Is it necessary to go to the dealership, or can it be done at any service center?
How much would it cost to replace the front bumper of a 2012 Phaeton at a dealership?
Is it necessary to change 2 liters of oil for a Lancer each time?
4My car has run 45,000 kilometers, and the third maintenance cost me 570. How much did your third maintenance cost?
5Is there a cost associated with changing the motor oil?
6What maintenance should be done at 100,000 kilometers? Do the transmission oil and gear oil need to be replaced?
7Is it necessary to change the transmission oil at 40,000 kilometers?
8Has anyone with the 2019 GA6 changed the transmission oil? Is it necessary to change it?
9I've driven my 2024 Wrangler for 10,000 kilometers. The first service was done at the 4S shop at 5,000 kilometers. They suggested I service it again at 10,000 kilometers. Do I need to change the engine oil this time?
10If I don't go to the 4S shop for maintenance during the warranty period, will it void the warranty? How much does it cost for maintenance at the 4S shop?
