How is the air conditioning performance in the Ford Ecosport during hot weather? Does it cool down quickly?
Is your air conditioning cool enough? Other cars can go down to 16 degrees, but I feel like the Swift only goes down to about 22 degrees. It's not very cool, but not too hot either. 🤦♂️
Has anyone picked up the C40? In this autumn weather, without using the air conditioning, how much does the range actually decrease?
How's the air conditioning performance? 🙏
4The air conditioning in the 2011 Kia Sportage has cool air but isn't cooling effectively. What could be the reason?
5When the air conditioning blows cold air for a while and then switches to hot air, and after being turned off for a bit, it works again before reverting to hot air, it's puzzling. Interestingly, this issue doesn't occur on rainy days or when the weather isn't too hot. What could be the cause of this situation?
6Why isn't the air conditioning in my Alto cooling?
7Hey folks, quick question. How can you quickly defog the air conditioning in a 2014 MG3?
8Is there anyone who understands why the air conditioning isn't cooling?
9Why is the rear air conditioning not cooling in the 2020 2.0 model?
10The air conditioning isn't cooling well. How do you guys usually fix this?
