زيد حسين
Feb 28
How do I turn off the maintenance lamp in a Toyota Corolla after an oil change?
عمر اميره2025-02-28 17:39
I tried this method on a 2020 Corolla, and it worked fine. But if you have a newer model, you might need to reset it through the infotainment system instead of the button. If you’re unsure, check the car’s manual or ask the dealership.
وسيم عبد العزيز2025-02-28 17:39
Turn off the ignition (the car should be off).
Press and hold the Trip/ODO button on the dashboard.
Turn on the ignition (without starting the car) and keep holding the button until the display resets to zero and the light disappears.
Turn off the ignition and restart the car. The maintenance lamp should now be off.
How do I turn on the heater and defog the windows in a second-generation Toyota Prius?
How do I turn the ESP on and off on a 2006 V8 Phaeton?
How do I turn off the alarm on the Multivan? When I'm lying in the car, the alarm goes off after a while.
4How do I turn off the center display screen in the MX5?
5How do I reset the trip meter after maintenance on a V40?
6How do I turn off the Eco mode on a 2014 Yaris?
7I've changed the oil. How do I reset the maintenance reminder?
8How do I turn off the engine start-stop system?
9How do I turn off the side mirrors on the 2021 Xingyao?
10How do I turn off the cabin floor lights?
