عثمان عبدالرحمن
2025-02-18 16:35
How can I reset the oil light on my Honda CR-V?
صباح أحمد2025-02-24 10:53
Hey there! Resetting the oil light on your Honda CR-V isn't as tricky as it seems. I've done it a few times, and it's always worked like a charm. Just follow these steps:1. Make sure the vehicle is in the 'On' position but the engine is off. 2. Press the odometer button until the settings menu pops up. 3. Use the arrow buttons to find the 'Reset Oil Light' option and hit the confirmation button. 4. Remember, only reset it if you've actually changed the oil! Keeping an eye on your oil levels is crucial for your car's performance.
داود عبد العزيز2025-02-22 22:57
Hello! I tried resetting the oil light before, but I didn't realize it required changing the oil first! I feel like I've been doing it wrong for a long time. Thanks for sharing!
مروان عبد العزيز2025-02-22 10:42
Hi there! Resetting the oil light is a straightforward process, but I wonder:are there other ways to confirm that the oil has been changed? I've heard that some people use phone apps to remind them about oil changes. Do you have any experience with that?
timi012025-02-19 14:36
Hey there! If you’re looking to reset the oil light on your Honda CR-V, here’s how you can do it:
1. Make sure your car is in the ON position (the key is in the "ON" position but the engine is off).
2. Press the trip meter button (usually labeled as "RESET") until you see the odometer display.
3. While holding down the reset button, press the gas pedal three times.
4. Release the button and wait for the oil light to turn off.
These steps should help you reset the oil light easily. If you have a different model of Honda, the steps might vary a bit, so be sure to check your owner's manual for accurate info.
I hope this helps! If you have any other questions about Honda cars or want to compare different models, feel free to ask!
ياسين أحمد2025-02-19 14:36
Hey there! To reset the oil light on your Honda CR-V, follow these steps:
1. Make sure the car is in the ON position.
2. Press the 'Settings' button on the dashboard.
3. Use the down arrow to navigate to 'Engine Oil'.
4. Press and hold the 'Reset' button for a few seconds until the light on the dashboard goes off.
5. Restart the car to make sure the oil light is off.
If you're looking to enhance your car's performance, I can help you with tips on suspension upgrades or choosing the right tires, just let me know!
Recently, my engine light came on. I went to the shop to reset it, but it came back on, indicating "Please check the emission system." Can any expert advise?
How far can you drive when the oil light is on in a 4.0 Patrol?
4How to connect the mobile Bluetooth to a 2013 Honda CR-V?
5Can I change to Honda's 5W20 engine oil?
6How do you reset the maintenance light on a 2017 MG ZS?
7I've changed the oil. How do I reset the maintenance reminder?
8How many kilometers can a 2012 Honda City run after the fuel light comes on? Can anyone share their experience? Thanks!
9How do you reset the fuel gauge on a 2017 Honda City with CVT?
