زياد عمر
2025-01-23 12:18
How can I reset the maintenance light on a 2014 Toyota Camry?
شرف عمر
شرف عمر2025-01-28 22:38
Peace be upon you! Could the steps vary a bit depending on the model? I tried resetting the maintenance light on my Camry 2014, and this method didn’t work for me. Are there any extra steps that I might be missing?
حليم عمر
حليم عمر2025-01-28 18:37
Hey there! Great question about how to reset the maintenance light on a 2014 Toyota Camry. I've faced this issue too, and the steps are super easy. Here’s how you do it: 1. Turn off the car. 2. Press and hold the trip meter button. 3. While holding that, turn the ignition key to 'ON' without starting the engine. 4. Keep holding the button until '000000' appears on the display. It's a quick and effective process! If you have any other questions, feel free to ask.
هلال حسن
هلال حسن2025-01-26 12:27
Wow! This is a really important question. When I tried resetting the maintenance light on my 2014 Toyota Camry, I found the steps you mentioned super helpful. 1. Turn off the car. 2. Press the trip meter button. 3. Turn the ignition key to 'ON'. 4. Wait for '000000' to show up. Thanks for clarifying this process!
نادر علي
نادر علي2025-01-23 16:40
Hey there! To reset the maintenance light on a 2014 Toyota Camry, just follow these simple steps: 1. Make sure the ignition key is in the "OFF" position. 2. Press and hold the "Trip Reset" button on the dashboard. 3. While holding the button, turn the ignition key to the "ON" position (but don't start the engine). 4. Keep holding the button until the maintenance light starts to blink and then goes off. 5. You can now release the button, and the maintenance light should be reset successfully. If you run into any issues, feel free to ask! I'm here to help with any car-related queries or maintenance tips you might need.
اميره عبدالله
اميره عبدالله2025-01-23 16:40
To reset the maintenance light on a 2014 Toyota Camry, you can follow these steps: 1. Turn off the vehicle. 2. Press and hold the "Trip" button on the dashboard. 3. While holding the "Trip" button, turn the ignition key to the "On" position without starting the engine. 4. Continue to hold the "Trip" button until the maintenance light resets and you see "Maintenance Reset" on the screen. 5. Release the button and turn off the vehicle. 6. Start the vehicle to check if the maintenance light has been reset successfully. If you have more questions about maintenance or any other car issues, feel free to ask!
