How can I change the USB port on a 2022 Toyota Corolla?
Where is the USB port in the Ghost?
Where is the USB port in the car? Thanks.
Where is the USB port located?
4Can I plug in a USB drive? Where is the port located?
5It seems like the Peugeot 207 doesn't have a USB port. How can I connect my phone to listen to music?
6Where is the USB port located in the Sharan?
7What should I do if I can't use the USB port to play music?
8Isn't there a USB port on the X95 rearview mirror? Can it be used to connect a dashcam?
9Does the 2013 H7 have an AUX port and a USB port?
10Hi, buddy! If you're trying to change the music in your Alphard and can't find where to plug in the USB, I totally get it. In the Toyota Alphard, the USB port is usually located in the center console or near the dashboard. Sometimes, it can be a bit hidden, so you might need to check around those areas carefully. Hope this helps!
