How can I change the timing belt on a Mitsubishi L200?
Comments( 7 )
Do I need to change the timing belt at nearly 90,000 kilometers?
Is the 2013 automatic Kia Sportage equipped with a timing belt or a timing chain?
How many kilometers should the Kia Pegas drive before changing the belt?
4How many kilometers should the timing belt of the V97 be replaced?
5How often should the timing belt and accessory belt be replaced on your Santana?
6How often should the timing belt be replaced? My car is over 9 years old with 81,000 kilometers on it. Do I need to replace the timing belt? Thanks to all the fellow car enthusiasts.
7How many kilometers before the timing belt of the Volkswagen Santana needs to be replaced?
8Is it necessary to replace the accessory belt when changing the timing belt?
9How many kilometers do you guys usually change the timing belt?
10I have an 11-year-old Sportage that's done 140,000 kilometers and I haven't changed the timing belt yet. Dear friends, at how many kilometers did you change yours?
