How can I adjust the clutch cable on a Hyundai i10?
Is the clutch too heavy? Can it be adjusted to be lighter?
How to install a dash cam? I can't find a place to run the cables. Can anyone help with this? It would be great if you could show where the cables should go. Thanks! 🙏
How can I adjust the clutch on a Peugeot 206 if it's too high?
4How can I adjust the high and low beam headlights inside the car?
5Is the clutch adjustable on the manual Changan Yuexiang?
6Hello, everyone. For the 2018 model with the 1.6 engine, do you find the clutch pedal heavy? Can it be adjusted?
7How long is the body of the Hyundai i10?
8Can I get this car serviced at a Hyundai 4S shop?
9Where can I adjust the regenerative braking strength of the Aria? How many levels are there?
10Can I go to the Hyundai 4S shop for maintenance? 😂
