عبد العزيز سهيل
2024-11-19 23:12
The 235,200 price for the dual-engine two-wheel drive elite seven-seater, including five regular maintenance services, electric tailgate, and fixed running boards, seems reasonable.
أحمد مصطفى
أحمد مصطفى2024-11-21 15:47
This is the price without interest, right?
علي خضير
علي خضير2024-11-21 09:32
When was it ordered?
سلمان أحمد
سلمان أحمد2024-11-19 23:34
Is it a full payment? Is there a trade-in? If there's no trade-in, a full payment would be quite cheap.
If you are experiencing an issue with your Mitsubishi Galant where holding the lock button causes the yellow light to come on and the window control buttons become unresponsive, here are a few steps you can try: 1. **Reset the System**: Sometimes, simply turning off the car and restarting it can reset the electronic systems, including the window controls. 2. **Check the Fuses**: Locate the fuse box and check if any of the fuses related to the power windows or central locking system are blown. Replace any blown fuses with the correct type and rating. 3. **Inspect the Battery**: Ensure that your car battery is not low on charge, as insufficient power can cause electronic systems to malfunction. 4. **Consult the Manual**: Refer to your vehicle's owner manual for any specific troubleshooting steps related to the power windows and central locking system. 5. **Visit a Technician**: If none of the above steps work, it might be best to consult a professional mechanic or visit a Mitsubishi service center to diagnose and fix the issue. Please do not attempt to fix any electrical issues if you're not familiar with car electronics, as it might lead to further damage.
Can I legally change a five-seater Touran to a seven-seater?
If the 95 comes out with a five-seat version and updates its interior, sales would definitely increase. The seven-seater really can't compete with other manufacturers.
What should I pay attention to when installing electric running boards on the Elite version with air suspension? Do I need to select the jack mode?
In the 2019 JETOUR X90 Enjoy Edition 6-seater with a 6DCT dry dual-clutch transmission, currently at 120,000 kilometers, an issue has been occurring since around 90,000 kilometers. When starting the car cold, everything is normal during acceleration. However, after driving for about half an hour and the engine warms up, when stopping or waiting at a traffic light and then trying to accelerate again, the car doesn't respond to the throttle. If you press the throttle harder, the engine stalls. When you feel the engine shake while pressing the throttle, if you release the pedal immediately and then press it again, the car can start moving, and everything works normally after that. There are no fault codes detected by the computer, and the spark plugs have been replaced. The engine checks out normal at the 4S shop. I'm seeking advice from experts on how to resolve this issue or if any fellow JETOUR X90 owners have experienced a similar problem and how they got it fixed. Thank you very much for your help!
Is it worth it to spend around 100,000, including interest, for a Jietu automatic 1.5T seven-seater?
I just bought a new manual 4WD Night Eagle, and after driving just over a thousand kilometers, there are all sorts of strange noises. I've been to the service center seven or eight times, and it's still not fixed. I'm really frustrated! Does anyone know what these noises could be? It's a new car, what should I do with it?!
Toyota Toyota Highlander
Toyota HighlanderAED 84,667 ~ 199,900Hybrid
