How do you turn on the 4WD switch in the 2024 Hybrid Highlander?
Hi everyone, for the 2021 Toyota Land Cruiser Prado LTD, how do you switch between high-speed 4WD and low-speed 4WD? When driving in full-time 4WD, do I need to come to a complete stop to switch between high and low-speed 4WD? Thanks!!
What do you think of the Magotan Hybrid?
How do I turn on the headlights when unlocking the vehicle at night? The headlight switch is set to the auto position.
4How do you turn on the high beam for the 206? The low beams can be turned on and the high beams can be activated by pulling the switch back, but it can't be pushed forward. What's going on?
5What's the fuel consumption of the Grand Highlander? If it's similar to the plug-in hybrid models in China, then it might be better to go for the Grand Highlander and avoid the hassle of charging.
6How is the 2024 hybrid Sylphy with a three-cylinder engine?
7How do I engage the 4WD?
8Do you all remember the Highlander 2.7L climbing issue back in the day? If the Tahoe had a 2.7L engine, with no models equipped with three locks and none featuring a standard 4WD system, would it also face a climbing issue?
9How do you turn the headlights on and off?
10How do you turn off the rear seatbelt reminder on this car?
