خالد ق
2024-08-24 14:20
Does the 2024 Highlander's particulate filter still get clogged? Fellow car enthusiasts, is your particulate filter still getting clogged? I've heard that the materials used now are better, so the chances of clogging are lower. I'm considering just replacing it with an empty shell to avoid future headaches.
سلمان يعقوبي
سلمان يعقوبي2024-08-24 18:59
That usually wouldn't be the case.
20
Hey car enthusiasts, I'm having some brake issues with my 2010 Volvo S80L. The brakes work fine when moving forward, but there's a chance of brake failure during short-distance reversing. A few days ago, when I changed the brake fluid, it was noticeably slow to drain out before adding the new fluid. Could it be that the brake fluid line is clogged? The brake pads are still quite thick, so I can basically rule them out. Any advice from the experts? 😬😬😬
Where is the Subaru's particulate filter located, and will short city commutes of 3-5 km cause it to clog easily?
The display indicating that the particulate filter is regenerating in your T-Cross means that the system is cleaning the diesel particulate filter (DPF). This process is normal for diesel vehicles and helps maintain performance by burning off accumulated soot. You can still drive your car while this regeneration process is ongoing.
Hi, for a 2011 Suzuki Swift 1.5 automatic that's run 110,000 km, here's what you might want to consider for maintenance to avoid getting ripped off: 1. **Oil Change**: Check and replace the engine oil and oil filter. 2. **Transmission Fluid**: Inspect and possibly replace the transmission fluid. 3. **Brake System**: Check the brake pads and brake fluid. 4. **Coolant**: Inspect the coolant level and top up or replace if necessary. 5. **Air Filter**: Check the air filter and replace if dirty. 6. **Tires**: Check tire pressure and tread wear. 7. **Battery**: Test the battery to ensure it's in good condition. 8. **Belts and Hoses**: Inspect for any wear and tear. It's always a good idea to consult your vehicle's manual or a trusted mechanic for specific recommendations.
Toyota Toyota Highlander
Toyota HighlanderAED 84,667 ~ 199,900Hybrid
