أحمد فادي
2024-11-19 11:05
Choosing between the Highlander and the Grand Highlander (陆放) can be a bit tricky, especially if you're planning to drive it for at least ten years. Both are solid options, but here are a few things to consider: 1. **Usage**: Since you'll be using it mostly for commuting, with occasional trips to the countryside or highway, both models should handle that well. 2. **Fuel Type**: Deciding between gasoline and hybrid depends on your priority. If fuel economy is important, the hybrid might be the better choice, as it generally offers better fuel efficiency especially in city driving. 3. **Fuel Consumption**: For the gasoline versions, the fuel consumption can vary depending on driving conditions and habits. Generally, both models have decent fuel economy for their size. You'll find the hybrid versions to likely be more economical in the long run. Ultimately, your choice might come down to budget, personal preference, and which features are most important to you.
كلثوم أحمد
كلثوم أحمد2024-11-20 11:21
The Land Cruiser has power loss, and the cause hasn't been identified yet. Consider buying a Highlander instead. [I need a moment]
سلمان ثابت
سلمان ثابت2024-11-19 20:00
Highlander Hybrid
خالد زيلاخ
خالد زيلاخ2024-11-19 14:39
They are the same thing.
محمد صلاح
محمد صلاح2024-11-19 13:35
The GWM RAV4 runs out of power [I want to be alone].
