سعود عَبْدُ الله
سعود عَبْدُ الله
Mar 9
The 2022 Haval H9 is approaching 40,000 kilometers, and I'm not sure how much longer the original spark plugs will last. Fellow car enthusiasts, at how many kilometers did you change your spark plugs? What condition were the spark plugs when you replaced them? Thanks! ***** Also, I've clearly stated it's the Haval H9 and posted this in the Haval H9 section. Please make sure it stays within the Haval H9 circle and not other H9 circles. It's really tiring, you're quite something! *****
سعود أيوب
سعود أيوب2024-11-22 22:05
It depends on the driving environment; regular off-roading and commuting to work are different.
عبد المجيد علي
عبد المجيد علي2024-03-10 06:20
Whether to change or not depends on the situation. Don't waste it if it's not necessary to change.
حسين صعدة
حسين صعدة2024-03-09 21:23
60,000 km service
20
سعود عَبْدُ الله
سعود عَبْدُ الله2024-03-09 16:33
The previous post was shared in the Hongqi H9 community.
Hey guys, at how many kilometers did you change your spark plugs? 😎
I've driven nearly 40,000 kilometers and I'm thinking about changing the spark plugs. Which model should I choose between Bosch and NGK? I saw a Bosch double platinum spark plug online. Is it necessary for this car to use double platinum?
The original spark plug failed after just over 10,000 kilometers. How about you guys?
How often should the spark plugs in the 2019 GS5 be replaced? It's approaching 70,000 kilometers and hasn't been changed yet.
Car enthusiasts: My Yuxiang has now run 50,000 kilometers. Do I need to replace the spark plugs? If anyone knows, please share. Thanks!
Yesterday, I went for maintenance and replaced the spark plug assembly. I want to ask, after a year and having driven 20,000 kilometers, is it necessary to replace it?
Is the lack of power when going uphill and the rise in RPM without an increase in speed in your fuel-powered Song Plus due to a spark plug issue? It's only driven 19,000 kilometers.
Hey everyone, at how many kilometers did you replace your car's original spark plugs? I'm at 80,000 km now, and the car starts up instantly. Not sure if I should replace them.
My Taurus just hit 30,000 kilometers. What maintenance does it need? Do I need to change the spark plugs and brake fluid? Thanks, everyone!
Haval H9
Haval H9TBDGasoline
