For the 2023 Haval H9, do you all use 92 or 95 octane fuel?
نايف سليم2024-11-23 21:13
98 refers to the octane rating of gasoline. In the context of cars, it often indicates premium fuel that has a higher resistance to knocking.
حسين جم2024-11-23 17:16
I've always used 92, but you can use 95 if you want.
أحمد نعيم2024-11-23 13:31
The main difference between 92 and 95 is the anti-knock properties, which is related to the engine's compression ratio. Personally, I feel that as long as the fuel quality is up to standard, 92 is sufficient, and 95 is not necessary.
أحمد عَبْدُ الْعَزِيز2024-11-23 10:24
I don't know about the second generation, but for the first generation, I've never used 95, always used 92! It's like a wild boar can't appreciate fine feed.
