مهدي سلمان
2024-12-05 21:06
Why can't I lock the Haval H6 Classic by touching the handle sensor area, but I can unlock it by gripping the inner side?
علي شجاع
علي شجاع2024-12-05 21:39
Long press to lock the car.
عمر اسماعيل
عمر اسماعيل2024-12-05 21:33
[Thumbs Up] Press like this.
Does the Jeep Renegade have one-touch window up and down, automatic window locking when exiting, and side mirror folding functions?
I reset the central control screen to factory settings. Now, the keyless entry can only lock but not unlock. How do I set it up? There is power! It seems to be protected. How do I unlock the system?
I want to ask about the 2013 model, how to disable the horn sound when unlocking and locking the car?
How can I get the side mirrors of a Jetour X70 to automatically fold when locking the car?
Does anyone know how to set up the feature where you can unlock the car by bringing the key close to the handle and lock the door by pressing the handle?
What should I do if the key of the 2022 HS7 can't open the tailgate, and the sensor can't lock the car doors? Thanks.
Hey car enthusiasts, have you ever experienced the trunk opening when you press the car key to unlock or lock the car? The sensor works fine for opening and locking the doors! But when I use the key to press the trunk button, it opens. What's going on??
The car won't lock with keyless entry, and there's a beeping sound. How can I fix this? It unlocks fine, but there's a beep when trying to lock.
My Kodiaq's rear tire is wearing unevenly, with noticeable wear on the inner side. The repair shop says I need to replace the lower arm because it can't be adjusted, and then do a four-wheel alignment. Is this the case?
The car won't lock, and the side mirrors close halfway and then open again by themselves. How should I deal with this?
Haval Haval H6
Haval H6AED 75,900 ~ 104,900Gasoline & Petrol
