حسين كاظم
حسين كاظم
Dec 5
I've had my new car for a month. Initially, I felt like the acceleration was too slow and the gear shifting wasn't responsive, since I was always driving in standard mode. But yesterday, I suddenly noticed that the power has increased and the gear shifting is more responsive. What's going on?
جلال الدين محمد
جلال الدين محمد2024-12-05 21:06
Maybe you're using the wrong mode.
The gear shift light for the 150 isn't on. Could it be because a button wasn't pressed, like the ones for P, R, D?
The gear shifting feels jerky. When going downhill, just a tap on the brake slows it down to the minimum speed. The fuel consumption is too high, basically 11 liters in the city.
Fellow car enthusiasts, have you experienced slow shifting between the 6th and 7th gears with your 7-speed dry dual-clutch transmission? Mine doesn't shift to 7th gear even at 80 km/h and waits until it reaches 85 km/h. Is this normal?
Are there any T-Cross owners here? Is your car shifting smoothly? I feel like my gear shifts are quite slow.
Before driving, I can only shift gears by pressing the shift lock button, and once I shift back to the P gear, I have to press the lock button again to shift! The brake lights are working fine! I recently replaced the handbrake cable and gear cable. Has anyone else experienced this situation?
My wife bought an 18-year-old used car, and today I drove it for a few dozen kilometers. I have a habit of occasionally resting my hand on the gear shift. When I did that, I noticed an issue. When shifting from second to first gear, I felt a slight "ka-ta" sensation! The sound is very faint, and you probably wouldn't notice it without your hand on the gear shift. Is this indicating a problem?
Yesterday, I went to the dealership to check the air conditioning pressure. It was at 16 psi and the temperature was 7.6 degrees, and they said everything was fine. But by noon, it wasn't cooling anymore. 🤦‍♂️
I went for a test drive of the 009 yesterday, and the smell was quite strong. I felt nauseous for the whole afternoon afterward. Have any of you experienced something like this?
How often do you guys change your oil? I did my first oil change after over 6000 km, and then again close to 12000 km. I drive 80% on highways and the rest in the city. I always refuel with PetroChina and Sinopec. After a recent trip of over a thousand kilometers on the highway, I felt the accelerator wasn't as responsive, so I changed the oil again.
Haval H6
Haval H6KWD 5,500 ~ 8,534Gasoline & Petrol
