How many days can the third-generation classic Haval H6 be left unused before the battery runs out?
The third-generation Haval H6 MAX occasionally has a noticeable jerk or thump when starting at a red light. Does anyone have any solutions to fix this?
Has there been a situation with your JETOUR X70 where the battery runs out of power even before reaching 500 kilometers?
Does your car battery often run out of charge?
4If you leave your car key (spare key) inside the car, it runs out of battery in just one afternoon.
5Does anyone know if the light inside the trunk of a Haval H2 stays on continuously when opened? If I keep it open for half a day, will it drain the battery? Some car models have a feature where the trunk light turns off automatically to prevent battery drain.
6What brand is the battery in your 3rd generation Haval H6? Mine is Leoch.
7Hey car enthusiasts, just wondering, will the car give a warning to replace the key battery before it runs out?
8How long does everyone's car battery last? Mine only lasts about two years before it runs out. Does the start-stop function consume that much power?
9Does your key run out of battery every two years?
10Is it normal for a Cayenne's battery to drain to the point where it can't be charged after not being used for a month in the third year? After replacing it with a new battery, it drains after about 20 days of not being used. This has happened several times. Is this normal?
