The car has run 1800 kilometers and there's 160 kilometers worth of fuel left. The next day when driving, it feels powerless. Has anyone else experienced this?
How many kilometers can a single fuel tank of an FJ72 run?
How many kilometers can a 301 run with an additional 200 RMB worth of fuel?
The steering wheel of the 2016 Crossover Yizhi is not aligned properly and is tilted to the left. The left side is further from the driver, and the right side is closer. Has anyone else experienced this issue, and is there a solution?
4I've been hearing a strange noise from the left side of the dashboard when I press the accelerator in the morning. It feels like a vibration. Have any of you experienced something similar? I'll upload a video next time.
5Has anyone else experienced this? Is it just me or is it a common issue?
6Hey fellow car owners, has anyone experienced oil leakage after the car has run over 80,000 kilometers? Any solutions? [Facepalm]
7Isn't it too fuel-consuming if a full tank only runs 440 kilometers?
8Has anyone else experienced the issue where the car's data is turned off by default these past two days, and you have to manually turn on the network? How did you solve it?
9Is it normal that a new car with 400 RMB worth of fuel, approximately 50 liters, runs over 500 kilometers?
10Can I use 5W-20 oil for an old Mazda with a 623 displacement that has run 300,000 kilometers? The 30 oil feels a bit thick. 😬
