Is the severe shaking of the driver's side window when lowered a common issue with the Lingfang?
Comments( 6 )
The passenger side window suddenly won't go up or down, and the driver's side window has broken once before. I can't really vouch for Iveco's quality!
For the 2009 Yuxiang, the driver's door often won't open. I have to lower the window and use the mechanical key from the outside several times. The other three doors are fine. Can someone tell me if this is a common issue with the old Yuxiang? [Facepalm]
4Hey folks, the car is uneven on one side, the driver's side is 3cm lower. I've replaced all the springs and shock absorbers, and also changed all the chassis bushings, but it's still the same. The driver's side leans heavily when turning. Can any experts offer some advice?
5After turning off the engine and locking the car, the driver's side window automatically rolls down. While driving, the driver's window button is sometimes responsive and sometimes not. Whether raising or lowering, once the button is pressed, the window moves directly to the bottom and won't stop in the middle. After reaching the end, you can still hear a clicking sound inside the door panel. Is the window button broken? Could you provide a replacement tutorial, preferably with a video?
6When driving at high speeds, there's a ticking noise from the driver's side window that sounds like raindrops hitting the glass. At first, I thought it was raining, but it wasn't. The right window is fine. The noise disappears when I lower the window. Could it be caused by the window seal? Has anyone else experienced this? How did you solve it?
7Is the hood of the Grand Cherokee lower on the right side? When sitting in the driver's seat and the passenger seat, the hood seems to have different heights. From the passenger seat, the right side of the hood appears to have a greater curve, but from the driver's seat, the left side doesn't seem to have as much curve as the right. The car is parked on level ground, and the seats are adjusted the same, but the issue persists. However, when viewed from outside the car, there seems to be no problem. Is this a visual perception issue?
8Four years, 40,000 km, 1.5T F56. There's noticeable shaking and noise at idle. Is this common for everyone? I bought it second-hand, so I'm not sure how it was when new. Also, when driving on rough roads, there's noise from the left and right side windows. When the windows are down, there's no noise. I suspect it might be the frameless doors causing the glass to rub against the body. Does anyone else experience this?
9Today, I suddenly found that the driver's side window won't roll down, but I can hear the motor running. What could be the issue?
10When the window glass in the Outlander's cabin is lowered and the door is closed with a bang, what's going on?
