عبد العزيز احمد
2024-03-15 14:16
Is there anyone else experiencing severe battery drain with their Hongqi H7? If I don't drive for four days, the car won't start due to significant battery loss.
ماجد عبدالله
ماجد عبدالله2024-04-01 12:10
I've had no issue starting my car on the first try for the past four weeks.
محمد عفان
محمد عفان2024-03-24 18:34
No such question.
حكيم سلمان
حكيم سلمان2024-03-24 10:09
There is no such question.
I bought the car in August 2020, and now it often won't start. Is the battery drained?
I've only had my car for ten days, and it won't start. Checked the battery, and it's fine. Not sure what's wrong.
How's your car battery? Mine won't start after sitting for three days. Any advice?
Why does the 2022 GA6 luxury version always prompt that the battery is low every three to four days?
I'm planning to buy the dual-motor version of X. Can you tell me how much the battery might drain if I don't use it for half a month?
Does anyone know if the light inside the trunk of a Haval H2 stays on continuously when opened? If I keep it open for half a day, will it drain the battery? Some car models have a feature where the trunk light turns off automatically to prevent battery drain.
If you left your car in D gear overnight and found it without power the next morning, it could be due to the battery being drained. Does anyone know why this happened?
Is it normal for a Cayenne's battery to drain to the point where it can't be charged after not being used for a month in the third year? After replacing it with a new battery, it drains after about 20 days of not being used. This has happened several times. Is this normal?
Is it advisable to buy a 2019 Ford Territory with the highest trim level if it keeps triggering the alarm automatically all day until the battery is drained?
Hongqi Hongqi H7
Hongqi H7AED 149,000 ~ 160,000Gasoline
