How can I adjust the headlights to aim higher? The low beams are too low on my 2018 1.8T model.
Hi guys, does the 2017 GS7 1.8T have halogen bulbs or xenon bulbs for the low beam headlights?
How do I adjust the headlight height on my 2021 Toyota Prado Off-road version? The headlight beams on my car are a bit high.
How can I adjust the high and low beam headlights inside the car?
4The washer fluid on my Rapid is spraying too coarse and too low, hitting below the wiper blades. How can I adjust it to spray finer and higher?
5The windshield washer spray on the Rapid is too coarse and too low, spraying below the wipers. How can I adjust it to be finer and higher?
6Can the low beam headlights of the 2010 Peugeot 207 be adjusted for height?
7How can I adjust the headlights to aim higher? The low beams are too low on my 2018 1.8T model.
8How can I adjust the low beam height on my H7? They're too low. Also, how do I use the headlight cleaning system? Waiting for some advice from fellow car enthusiasts. 🙏
9How do I adjust the low beam height on the Hongqi H7? It's too low. Also, how do I use the headlight washer? Waiting online for help from fellow car enthusiasts. 🙏
10For a 2012 Kia Sportage with integrated headlights, if adjusting the low beam to the right position causes the high beam to point at the treetops, does anyone know how to solve this? How can the high beam be adjusted lower without moving the low beam?
