علي عاطف
2023-08-12 08:34
Hey fellow car enthusiasts, does anyone else have issues with their Haval H7 keyless entry being inconsistent? Sometimes it works fine, but other times it's unreliable. Especially on rainy days, it often doesn't work.
Comments( 6 )
حكيم سلمان
حكيم سلمان2023-12-06 10:10
Currently, this situation has not been observed.
عبدالرحمن بهاء
عبدالرحمن بهاء2023-12-05 23:08
Replacing the battery yourself should fix it if the battery is low on charge.
علي عاطف
علي عاطف2023-09-16 21:49
I found the problem. It doesn't work when the car key is in the bag. [I need some peace][I need some peace][I need some peace]
محمد باسل
محمد باسل2023-09-07 13:06
Almost like this.
عبدله سلمان
عبدله سلمان2023-08-17 15:44
There's no such situation. But don't pull or yank it hard.
خليف فهد
خليف فهد2023-08-12 21:01
There hasn't been such a situation.
To all Haval owners, is your infotainment screen working fine?
The keyless entry function on the GS 5 is not working properly. Approaching the vehicle no longer locks or unlocks it, and the function is unresponsive. The key fob's battery was just replaced. What's going on here?
After upgrading the central control screen, the car's audio sometimes works fine, sometimes only the right loudspeaker works, and sometimes there's no sound at all. What's going on?
After leaving the 2012 Koleos in an open-air parking lot for half a month during heavy rain, the keyless entry on the front doors suddenly stopped working, while the rear doors are fine. Has anyone experienced this situation? Is it a wiring issue or are the keyless entry sensors malfunctioning? PS: It's not a key battery issue.
What could be the reason for the Haval H2's push-start sometimes working and sometimes not?
The car won't lock with keyless entry, and there's a beeping sound. How can I fix this? It unlocks fine, but there's a beep when trying to lock.
The screen was working fine until the afternoon, but after being exposed to the sun all day, it started to malfunction. What can I do to fix the screen issue without replacing the car stereo? I'm concerned about the repair cost being too high. Is there a way to fix it myself?
My keyless entry only works on the rear side of the driver's seat. Is it broken?
Only the driver's side keyless entry is working, and I've checked the settings, everything seems fine. The auto start-stop isn't activating anymore either, though I don't really use it. Has anyone else encountered the same issues?
Hongqi Hongqi H7
Hongqi H7AED 149,000 ~ 160,000Gasoline
