Have you experienced a situation where the welcome light on the driver's side doesn't light up, but the other three doors do?
Is there any other Coaster owner experiencing the same issue where the engine RPM fluctuates up and down while coasting in neutral?
The co-driver's window of the Mitsubishi Eclipse Cross can only go up but not down, and the main driver's switch can control the other three windows except the co-driver's, which can only go up but not down. The co-driver's switch also only allows the window to go up but not down. What could be the reason for this?
4How to remove the door panel for the driver's side due to noise?
5Hi everyone, does the backup light on the Suzuki SX4 light up on both sides or just one side?
6The rear tail light on the driver's side doesn't light up when I brake. I just replaced the bulb half a month ago, and now it's not lighting up again. The previous inspection said it wasn't a bulb issue. Has anyone else experienced this? What's the problem?
7Why does the driver's door not open with the key unlock button after locking the car from the outside, while the other three doors can be opened?
82014 Peugeot 2008 manual transmission, the remote key can't unlock the driver's door (can open with the key), while the other three doors work fine. Any advice on how to solve this issue? 🙏🙏🙏
9Can the footwell lights of the RDX for both the driver and passenger sides be adjusted to be brighter?
10Is there a modification available for the 2023 model 1.6T where the middle part of the through-type taillight doesn't light up?
