Why is the engine light on my 2017 Haval H2 Red Label Automatic 1.5T Luxury always on and not turning off?
Will the driving lights turn off automatically after locking the car if they are not switched off?
How can I set the car lights to turn off automatically when the door is closed? It's always draining the battery and it's super annoying...
4I have a 2018 Haval H2 Red Label with a manual transmission, and the touchscreen display isn't responding. Does anyone know what might be causing this issue?
5Does anyone know if the light inside the trunk of a Haval H2 stays on continuously when opened? If I keep it open for half a day, will it drain the battery? Some car models have a feature where the trunk light turns off automatically to prevent battery drain.
6The fuel tank capacity of the 2017 Haval H2 is 55 liters.
7Does the ambient light in your Haval turn off by itself? In my car, every time I connect the Bluetooth music to my phone, I have to turn it on again when I start the car. It always turns off by itself.
8I just got a 2016 Haval H2 Red Label 1.5T manual 2WD! But I don't know how to identify which version it is. Can anyone help me with this? Where can I find out? I just know it's a high-end model!
9Can the 2017 Haval H2 Automatic Elite be started with a mechanical key?
10Haval H2 Red Label 1.5T has currently run 85,000 kilometers. While driving at speeds between 60 to 100 km/h, there's a vibration and noise coming from the front wheels. What could be the cause of this issue?
