What could be the issue if the fuel gauge is empty, you fill up the tank, and it still doesn't respond?
What is the fuel consumption of the Maserati GTS, and how much fuel does it take to fill up the tank?
Why does the official spec say the car has a 65L fuel tank, but I can only fill it up with just over 30 liters?
Why does a 2006 Accent manual consume so much fuel? Filling up the tank for 340 RMB only allows it to run 450 kilometers.
4Hey fellow car enthusiasts, my Lancer's fuel gauge is below the red line, but the fuel light isn't on. I can only fill up 37 liters, but isn't this supposed to be a 50-liter tank? Has anyone tested this?
5I filled up the tank a week ago, and the displayed range hasn't changed. Is the sensor broken, or is it the fuel gauge float that's faulty?
6What could be the issue if the fuel gauge is empty, you fill up the tank, and it still doesn't respond?
7The fuel tank capacity of a Jetta is generally around 55 liters. If you're filling up about 57 or 58 liters each time, it could be due to the fuel already in the tank or variations in pump measurements.
8When the fuel gauge still shows three bars short after filling up the tank until the pump stops, what could be the reason?
9For the 2015 Peugeot 3008, the fuel gauge was previously inaccurate, and the fuel tank got dented. After replacing the charcoal canister and the gray filter, the fuel gauge is still not accurate, sometimes showing more and sometimes less.
10The fuel tank of the Venza Hybrid Premium is labeled as 55 liters, but I can't even fill it up to 50 liters. How about everyone else's experience?
