The rear tail light on the driver's side doesn't light up when I brake. I just replaced the bulb half a month ago, and now it's not lighting up again. The previous inspection said it wasn't a bulb issue. Has anyone else experienced this? What's the problem?
Picked up the car less than two months ago, got rear-ended with damages estimated at 40,000. Can I make him pay for the depreciation, guys? My heart aches.
After the vehicle inspection, a series of warning lights for ABS, ESC, electronic parking brake, and hill-start assist light up. Usually, they don't light up when I start driving, but after a while, they do. I went to the repair shop to clear the fault codes once, but after driving 20 to 30 kilometers, they came on again. Does anyone know what the cause might be?
4The rear tail light on the driver's side doesn't light up when I brake. I just replaced the bulb half a month ago, and now it's not lighting up again. The previous inspection said it wasn't a bulb issue. Has anyone else experienced this? What's the problem?
5The engine warning light came on after driving over 10,000 kilometers, right when it was time for maintenance. The service station checked and found the gas cap wasn't properly sealed, and they reset the computer. However, the yellow light came back on in less than half a month. The service station is too far away, and I don't have time to go there. Does anyone know what the problem might be? Any help would be appreciated.
6I need help with my 2019 1.5T Automatic Luxury Cabin version. I've been driving it for three and a half years, mainly in the city, and it's done over 31,000 kilometers. Recently, in the past two months, the fuel consumption has skyrocketed. When I fill up, the gauge shows 630 kilometers, but I can only actually drive just over 400 kilometers. Two months ago, I could easily drive around 550 kilometers. Does anyone know what's going on?
7Does the tail light of the 2019 GAC GA6 Automatic Premium version fully light up when the brake is applied? Could someone let me know?
8I did the first maintenance at 3,800 km in half a year, and now it's almost a year with only 6,500 km. The 4S shop notified me for maintenance again. Does everyone do maintenance every six months?
9I have a 2016 automatic Santana, and the ABS light occasionally turns on and off. When I took it for a check-up, they said there was no problem, and it drives fine. It's just annoying to see the light on. Any idea what's going on?
10I'm picking up a 2021 Peugeot 5008 Active version tomorrow, and the salesperson said there are 4 or 5 units to choose from. Could you give me some advice on how to choose and inspect the car?
