علي جمال الدين
علي جمال الدين
Sep 17
The issue with the cruise control not holding could be due to several reasons. While the indicator light on the dashboard shows that the cruise control is activated, it might not maintain the set speed.
سعود مكتوم
سعود مكتوم2024-11-01 01:19
Manual or automatic? Mine's manual. I used to have issues with the cruise control turning off by itself, and later found out it was because the clutch plate was worn out. [I need a moment]
أحمد توفيق
أحمد توفيق2024-09-22 11:14
My previous floor mat used to get stuck on the clutch pedal, even a little bit would cause problems. I later replaced it with a different mat.
علي سا مرعي
علي سا مرعي2024-09-17 21:15
If the brake pedal or clutch pedal doesn't fully return to its position, just pull it up a bit.
To activate the cruise control on the MX-5 NC, first make sure you're driving at your desired speed. Then, locate the cruise control button on your steering wheel or stalk and press it to turn on the system. Once activated, you should see a cruise control indicator light on your dashboard. Adjust the speed using the "Set" or "Resume" buttons as needed.
It could be due to several reasons such as engine misfire, idle air control valve issues, or even problems with the transmission mounts. It's best to have a mechanic check it out to diagnose the exact cause.
Why can't the cruise control on the LC300 be activated? It shows OFF and won't turn on no matter what I do.
Hello fellow car enthusiasts, have any of you experienced this issue where you double-click to activate LCC and it shows as available but just doesn't activate? What's going on, is there a setting problem?
How do you activate cruise control on a 2017 Smart? I've been trying for a long time but still can't figure it out.
The difference between canceling cruise control and turning off cruise control in a Patrol is essentially about how the system is deactivated. Canceling cruise control is a temporary deactivation, allowing you to resume the set speed later, while turning off cruise control completely deactivates the system until you set it up again.
The difference between the "Cancel Cruise" and "Turn Off Cruise" buttons on the steering wheel of a Patrol is as follows: - **Cancel Cruise**: This button temporarily deactivates the cruise control while keeping the set speed in memory. You can resume the cruise control to the previously set speed later without having to set it again. - **Turn Off Cruise**: This button completely deactivates the cruise control system and clears the set speed from memory. To use cruise control again, you would need to set the speed anew.
The dashboard shows a warning light, and when checked with a computer, it indicates an ignition module issue. Should I replace the ignition coil? There are no problems when driving normally.
After the central control was reset to factory settings, it shows that it can't connect to the network and can't enter the system.
Haval H2
Haval H2AED 54,900Gasoline
