Recently, I feel like the brightness and range of the H2's headlights are getting worse. Has anyone replaced the front headlights? Any guidance? It's a 2018 automatic model, with 60,000 kilometers.
I feel like the headlights aren't bright enough, especially the high beams. Do any fellow car enthusiasts know of any parts I can replace them with?
Does anyone feel that the headlights of the Yaris X are not bright enough? Has anyone modified the headlights, and are there any compatible headlights available now?
For a 2018 Model S 100D with 80,000-90,000 kilometers, the remaining battery range can be significantly different compared to a 2022 Model 3 or Model Y with a 78 kWh battery. The older Model S may experience some battery degradation over time, affecting its range. When considering a used car, it's understandable to be concerned about the battery's performance and capacity.
4Is the brightness of the GV80's headlights not sufficient? 🙏🙏🙏🙏 Thanks a lot.
5If you're deciding between a used Tesla Model S and a Mercedes-Benz EQC with a budget of 15, here's a brief comparison that might help: - **Tesla Model S:** Known for its long range, powerful performance, and access to Tesla's Supercharger network. It's a popular choice for those looking for an electric vehicle with a performance edge. - **Mercedes-Benz EQC:** Offers a luxurious interior, smooth ride, and is known for its comfort and build quality. It's a strong contender if you're looking for a more traditional luxury SUV feel in an electric vehicle. Your choice might depend on what you prioritize more: performance and range (Tesla) or luxury and comfort (Mercedes-Benz).
6I bought a used 2018 Peugeot 3008 and feel like the halogen lights aren't bright enough. I replaced them with LED bulbs, but the light is still scattered and not good. Could you suggest what bulbs I should use? Also, does the original car come with projector lenses?
7I have a 2018 Outlander 2.4 AWD. Last month, the right front wheel got hit, and I had to replace the shock absorber, half shaft, and steering rack. 😒😒😒 Now, when I'm driving at around 110 km/h, the steering wheel vibrates in my hands. It's not exactly a shake, but more of a tingling feeling. The car doesn't drift or vibrate, just the steering wheel. If I grip the wheel tightly, it feels a bit better. There's no issue when driving below 100 km/h. I've done wheel alignment, and the data is spot on. I've also done wheel balancing and swapped the front and rear tires. I've even replaced the front bearings, but there's no change. The repair shop said the next step would be to start replacing parts one by one, but that would be too costly. Does anyone know what the problem might be? I'd be willing to offer a small reward for a solution. 😏😏😏
8Taurus chassis noise I have a 2019 Taurus, bought in 2021, and it's now at 57,000 kilometers. Recently, there's been a serious noise coming from the chassis, and it gets worse as the weather gets hotter. When the vehicle goes over speed bumps or when the front wheels hit uneven road surfaces at different times, there's a squeaky sound from underneath, like metal rotating inside a rubber bushing. When entering the garage and turning the steering wheel left, there's a clunk noise from the front when the front wheels hit a speed bump. The same clunk noise happens when parking with the steering wheel fully turned while reversing. The noise is very uncomfortable. Any suggestions from fellow car enthusiasts? Has anyone else experienced this?
9I have a 2018 Haval H2 manual with a red badge. The ABS light is on, the central console reports an auto hold fault, a hill descent fault, and the steering wheel feels heavy as if it's lost power assist. Previously, a repair shop read the fault codes and showed a right rear wheel ABS fault. I replaced both rear wheel ABS sensors, but the issue persists, and now there's a new problem. Before, I could turn off the engine by pressing the start button once. Now, it doesn't turn off with one press; I have to press the brake and long-press the start button to force it to shut down. Does anyone know what's going on? I'm really fed up with this car. After this experience, I don't want to buy a GWM car again.
10Recently, I feel like the brightness and range of the H2's headlights are getting worse. Has anyone replaced the front headlights? Any guidance? It's a 2018 automatic model, with 60,000 kilometers.
