Location of the rear sunroof drain for the Haval H2.
The fuel tank capacity of the 2019 Haval H2 manual Fashion Edition is about 55 liters. What are your fuel consumption rates, everyone?
Haval H2's snow mode malfunctioned. Should I go to the 4S shop for repair?
Why is the engine light on my 2017 Haval H2 Red Label Automatic 1.5T Luxury always on and not turning off?
4Does anyone know if the light inside the trunk of a Haval H2 stays on continuously when opened? If I keep it open for half a day, will it drain the battery? Some car models have a feature where the trunk light turns off automatically to prevent battery drain.
5What could be the reason for the Haval H2's push-start sometimes working and sometimes not?
6The fuel tank capacity of the 2017 Haval H2 is 55 liters.
7Location of the rear sunroof drain for the Haval H2.
8Where is the drain plug for the manual transmission located?
9Can the 2017 Haval H2 Automatic Elite be started with a mechanical key?
10Is sunroof leaking and rear door handle not retracting a common issue?
