Is there a neutral switch in the Haval H2 manual? If so, where is it located?
Hey guys, how do you use the Jimny's differential lock, and where is switch 9 located?
Hey folks, my 2017 Haval H2 manual is jerky between 1st and 2nd gear. It feels really tough to shift gears. What's going on here?
The fuel tank capacity of the 2019 Haval H2 manual Fashion Edition is about 55 liters. What are your fuel consumption rates, everyone?
4Where is the anti-skid switch located for inspection? Thanks.
5I have a 2018 Haval H2 Red Label with a manual transmission, and the touchscreen display isn't responding. Does anyone know what might be causing this issue?
6The fuel tank capacity of the 2017 Haval H2 is 55 liters.
7Location of the rear sunroof drain for the Haval H2.
8Where is the drain plug for the manual transmission located?
9Can the 2017 Haval H2 Automatic Elite be started with a mechanical key?
10Where is the air conditioning switch function located?
