Is it normal for the 16 manual Elite model to feel sluggish when starting in 1st gear, or is there a problem with the car? Even when the revs are almost at 3000, the speed is still relatively slow.
Comments( 7 )
My car is automatic, and I recently noticed that when I start on an uphill, there's a kind of "bo bo" sound when I press the gas. It seems like it's coming from the transmission. But when I'm driving normally, there's no problem. Even when I hit the gas hard or drive on the highway, it's fine. It's just when I start on an uphill. 😂
Is the strong jerkiness when shifting from 1st gear to 2nd in your GA8 a common issue, or is there a problem with the car?
When your car is idling or waiting at a red light, can you hear a "ta-ta-ta" sound? I notice it every night after work when it's quiet, and it's really annoying. It's the same "ta-ta-ta" sound even if I rev the engine in neutral. The frequency of the sound is the same at different RPMs as when it's idling. Not sure what the issue is.
4The fuel consumption of the 1.6 isn't low, and the trunk is also small. It feels sluggish when driving and can't even match my old F3.
5When driving, if the car suddenly doesn't respond when you press the accelerator, and even flooring it doesn't increase the RPM, but releasing and pressing it again solves the issue, this could be a problem. When starting on a steep slope, if the car feels powerless and sometimes can't climb, requiring several attempts to increase RPM, there might be an issue to address.
6Is it normal for the 16 manual Elite model to feel sluggish when starting in 1st gear, or is there a problem with the car? Even when the revs are almost at 3000, the speed is still relatively slow.
7My Mitsubishi ASX struggles to go beyond 140 km/h on the highway, even with the pedal almost to the floor. The RPM is between 2600-2800. Usually, when driving, the accelerator feels a bit sluggish. Does anyone know what could be the reason?
8Is there anyone who has experienced this situation? When shifting from 1st to 2nd gear, the car doesn't accelerate even though the RPM goes up. I have to release the accelerator and then press it again to make it work. What's going on here? Is it a transmission issue or something else? How did you guys solve it?
9Is it normal for my manual comfort version car to have the engine rev up to 3000 RPM and make a lot of noise when driving over 100 km/h on the highway?
10I have a 2017 automatic model with 50,000 kilometers on it. Recently, I've noticed three particularly obvious issues: 1. When starting at traffic lights, even with light acceleration, I can hear the engine howling. The fuel consumption spikes to 19.9, the engine revs up to 2000 RPM, but the acceleration is very slow. 2. When driving home from work and going up the parking ramp, I often find that even with the gas pedal pressed, there's no power. The RPM goes up to 3000, and the fuel consumption also spikes. 3. Occasionally, when starting the car, it will shake and then stall by itself. Overall, driving at speeds between 0-40 is uncomfortable, but things improve above 60, especially on the highway. Acceleration and overtaking are fine at higher speeds. It's quite frustrating. Is anyone else experiencing the same issues?
